Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Like Tree1Likes
  • 1 Post By River
Unread 07-11-2012, 06:40 AM   #1 (permalink)
Buying used pickups?
Are second hand pups going to be the same as new ones?
Carl17 is offline   Reply With Quote
Unread 07-11-2012, 08:13 AM   #2 (permalink)
Send a message via Skype™ to NovaSDF
Re: Buying used pickups?
You aren't related to my wife by any chance? Reason I ask is that she tends to talk in riddles as well.
What pickups exactly are you talking about?
There are a lot of different pickups out there. If you are replacing one specific pickup with another of the exact brand and model, then it will likely be the same/similar. Occasionally you may have one that varies (usually for the worse - or what in the business is known as a dud.)
Two things you should never forget: 1 - The only time it's okay to work with amateurs is if you're making porn 2 - If you want to work with clowns, join a circus!
NovaSDF is offline   Reply With Quote
Unread 07-11-2012, 08:58 AM   #3 (permalink)
Humbuckers. Seymore Duncans to be specific, probably the JB model.
I could buy the pup new but it would save a bit of money to get them second hand and if it's going to be the same as getting them new, then I don't see a problem with second hand ones.
Unread 07-11-2012, 09:02 AM   #4 (permalink)
River's Avatar
They're not perishable, if that's what you mean.
Used ones won't have any warranty, might have had their leads shortened, and may not even work for that matter. Caveat emptor.
Webtroll likes this.
Unread 07-11-2012, 01:36 PM   #5 (permalink)
Ok I'll keep that in mind. And I meant would the sound quality be the same as a new one.
Unread 07-12-2012, 02:40 AM   #6 (permalink)
J-Dizzle's Avatar
theoretically, as long as they were looked after, buying used pups should be pretty much the same as buying new ones.
But some lazy ****tards cut the leads too short when removing them, as River said above. I've had that happen & its a pain in the ass.
But aside from that there should be no problemo.
J-Dizzle is offline   Reply With Quote
Unread 07-12-2012, 08:42 AM   #7 (permalink)
Huck Finn's Avatar
I'd just like to add that EVERY magnet on earth decreases in power over the years. That's why a very old pickup cannot sound as powerful as a new one. Not sure about how much it changes the sound and how many years have to pass until you hear a difference.
Huck Finn is offline   Reply With Quote
Unread 07-12-2012, 08:48 AM   #8 (permalink)
Thanks for the info, but I pulled 2 DiMarzios from a 1970's Hondo LP and the still sound great.Each measures around 8.5k
Unread 07-12-2012, 08:51 AM   #9 (permalink)
TeaForTwo's Avatar
Um, er, and um......100 years or so.......
Even then, there won't be much tonal difference........
" Tell 'em a hookah smoking caterpiller has given you the call."
" I have realized that I want to be buried in a pile of guitar pedals. " ; St. bede
TeaForTwo is offline   Reply With Quote
Unread 07-13-2012, 12:45 PM   #10 (permalink)
Huck Finn's Avatar
Guess why new "vintage" pickups don't have such strong magnets
Tags
pickups
