Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Unread 05-08-2012, 07:55 PM   #1 (permalink)
Les Paul wiring
Hello, I need help. I am now on my 4 th attempt at wiring my les Paul and failed. I have wired other les Paul's with success but this one is killing me. I have an epiphone that I completely gutted. I installed a new switchcraft switch, new cts 500k pots, and new alnico 2 pro slash pickups. I have attempted to wire it following the 50s style wiring schematic. (my first 3 attempts were with the old pots and switch and I was unable to get any sound). So I got all new parts and rewired 50s style. Now I have sound from both pickups and all 3 switch positions but the volume level is extremely low.
I have gone over the diagram and my setup and I don't see that I miswired anything including all the grounds. Does anyone have a suggestion for why I cannot get any volume out of this rig?
Thanks very much
Docpapalo is offline   Reply With Quote
Unread 05-08-2012, 08:02 PM   #2 (permalink)
2themax's Avatar
Re: Les Paul wiring
A picture will really help - that way the wiring gurus can see what you're doing... I'll be doing mine in few weeks and I plan to make a cardboard template and do most of my connections outside the guitar where it's easier access. Then do the final connections in the cavity.
Good luck...
Sometimes... "He had delusions of adequacy."
- Walter Kerr
2themax is offline   Reply With Quote
Unread 05-09-2012, 03:47 AM   #3 (permalink)
Re: Les Paul wiring
here is a pic of my wiring job. please tell me if you see an error. all of the equipment I used here, I have also used in other guitars with success. again the problem is that the volume output is extremely low
