#1 (permalink) |
Dysfunctional Member
![]() Join Date: Feb 2010
Wiring question....slide switch.
I'm going to be converting my Melody Maker SG into a 2 pickup guitar (hopefully). And in order to keep it more MM-esque I want to use a 3-way slide instead of a toggle. I'll me using CTS mini pots so that I can keep all 4 knobs on the pickguard. The slide switch is also a crammed space issue also. So help me out here, how should I wire this up for neck-both-bridge operation? Thanks fellas!
#2 (permalink) |
Re: Wiring question....slide switch.
i cant figure out how to do it with that switch
you need a dp3t Dunno if the make em in sliders. one pup to a2 and one pup to b1 jumper a0 and b0.. outbut to b0
______________________________________ Last edited by H.E.L.Shane; 04-16-2012 at 12:15 PM. |
#4 (permalink) | |
might have to go with a three position toggle with workings like i posted. the 8 prong ones are used on Mustangs for switching and phasing, two of them in conjunction, and wiring it is a whores nightmare. if you got room for two of those, you can do a mustang circuit. |
#5 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Jan 2009
I think you can do it like this:
![]() - Connect A1 to B1 - Connect the jack / output to A2 and B4 - Connect one pickup to A3 and B3 - Connect other pickup to B2 |
#6 (permalink) |
this should work
*Picture removed because I fail*
2006 Epiphone Les Paul Standard Honey Burst (Seymour Duncans) 2011 Epiphone Les Paul Standard Ebony 1997 Epiphone Les Paul Custom Black Beauty 2004 Fender Deluxe Stratocaster Pearl White 2011 Squire Classic Vibe Custom Telecaster Sunburst 2012 Les Paul Junior Replica *WIP*
