Go Back   Les Paul Forums > The Les Paul > The Custom Shop
Like Tree37Likes
Unread 02-17-2012, 11:54 AM   #31 (permalink)
likea45's Avatar
Re: Building BYOGuitar's Custom Shop 59 Kit.
Originally Posted by silverkw View Post
LOL. Just so that better kits coming out from them, right?
Indeed. I hope mine looks as nice as yours sans fretboard issue
silverkw likes this.
likea45 is offline   Reply With Quote
Unread 02-17-2012, 11:58 AM   #32 (permalink)
Bartlett Retrospec Member
silverkw's Avatar
You mentioned SG kit, so which kit did you order?
silverkw is offline   Reply With Quote
Unread 02-18-2012, 02:09 PM   #33 (permalink)
likea45's Avatar
I started with the custom shop SG kit they had there and then started upgrading from there. Essentially ive had them make me an SG custom, spec'd out as close as close can get, large headstock, 61 neck joint etc. I'm very excited to get it and begin the process.
SG Lou and silverkw like this.
Unread 02-26-2012, 02:25 PM   #34 (permalink)
likea45's Avatar
Have you got your replacement board yet? I'm starting to get very concerned as I've heard no word about my kit in some time. Let me know if you got yours.
Ignite the borealis
Unread 02-26-2012, 02:59 PM   #35 (permalink)
SG Lou's Avatar
Looking forward to see that!
And thanks for the kind word's but I just get lucky from time to time, that's all
"It's all Iommi's fault. I blame him entirely"
A.L.S. aka Lou Gehrig's disease Sux.
Lets rid the world of this dreaded disease
I CAN'T SEE OR POST PICS,PHOTOBUCKET IS BLOCKED ON WORK PC'S
Moritz Guitars
stmoritzguitars@hotmail.com
Guitars:
64 SG Special
Custom Shop Iommi Sig. SG
Epi Iommi SG
Jaydee "Old Boy" SG
Custom Built "Old Boy" SG replica
63 RI Strat
Amps:
Laney GL50 head w/4x12 Laney Cab.
Laney LC15R, Line6 Spyder
SG Lou is offline   Reply With Quote
Unread 02-27-2012, 01:26 AM   #36 (permalink)
silverkw's Avatar
They said my board has been sent out last week. Hopefully I will get it later this week, I hope this one would turn out better than the last
Unread 02-27-2012, 02:06 AM   #37 (permalink)
likea45's Avatar
Did it take a month for the kit to arrive the first time?
Ignite the borealis
Unread 02-27-2012, 10:24 AM   #38 (permalink)
silverkw's Avatar
No, from the time it was sent out it took about a week.
Actually, my buddy (at the US border) told me the board arrived, I am going to pick it up this afternoon!
Unread 02-28-2012, 11:34 PM   #39 (permalink)
likea45's Avatar
I ordered mine in late January and I guess it will be here tomorrow. Does a month and change seem acceptable for an order like this? Or am I just too used to Ebay?
Ignite the borealis
Unread 02-29-2012, 01:19 AM   #40 (permalink)
silverkw's Avatar
I guess it depends on:
- When it was sent out (more important)
- Where you are located.
Unread 02-29-2012, 10:24 PM   #41 (permalink)
likea45's Avatar
Finally mine came. Build thread here:
SG Custom BYOG Build
Ignite the borealis
Unread 04-02-2012, 04:44 PM   #42 (permalink)
silverkw's Avatar
Alright... some updates...
I decided to do a wrap tail configuration, like a refinished 56. The top join is off center by 1.5mm, which would play out nicely with the 56 wrap tail look.
- I got replacement board from BYO guitar a while ago.
- Glued on the neck to the body using hide glue (HUGE learning curve).
- Glued on the fretboard to the neck and body using hide glue (felt much more comfortable).
- Did a dry fit of important parts.
- Mounted pickup rings, made a couple of small mistakes, had to fill and re-drill a few pickup mounting ring screw holes.
- Used a tail mount and ABR-1 bridge to locate the wrap-tail position.
- Bought a used 8" drill press (best $20 I have ever spent!!!)
- Drilled the holes for the wrap-tail studs. I had to spend another $10 for the 7/16 drill bit, kind of a weird size, but the studs fit nice and true.
- Drilled the grounding wire hole from bridge PU cavity to the treble side stud, this is way more logical than drilling from control cavity.
- Mounted the wrap tail and adjusted intonation slightly. The string spacing is very nice.
- And it plays and sounds lovely! Needs maybe very slight fret leveling, but the guitar just sings! Of course it has no finish yet.
GammyBird likes this.
Unread 04-03-2012, 12:36 AM   #43 (permalink)
likea45's Avatar
Looking good!
Ignite the borealis
Unread 04-03-2012, 08:35 AM   #44 (permalink)
ddroz60lp's Avatar
Man, I am digging that grain on the top.What do you think of the quality overall so far?
Gibson 2007 Les Paul Plaintop 60 reissue Lemonburst
Martin 2011 000 MMV
Bulldog Bodies Les Paul Replica Faded Cherryburst
Gibson 2002 Sg Special
Gibson 2012 Les Paul Junior Special
Kiralu Kookscaster
Custom Allparts Tele Relic
Fender 2006 S.R.V.
Silver Creek T-160
Peavey Classic 50 4x10.
ddroz60lp is offline   Reply With Quote
Unread 04-03-2012, 09:17 AM   #45 (permalink)
silverkw's Avatar
The quality is good, fitment of the neck is great.
I can't say it's as great and as historically correct as say, a Bartlett kit, but then again, you have to consider the price.
Unread 04-10-2012, 10:57 AM   #46 (permalink)
silverkw's Avatar
Some more progress.
I HATE GRAIN FILLING... It sucks but it's a must... I am glad it's over... I used a darker filler since I am going for a dark back (not as BLACK as Gibson CS' dark back though).
Unread 04-10-2012, 11:38 AM   #47 (permalink)
likea45's Avatar
The joys of finishing....coming together though.
Ignite the borealis
Unread 04-10-2012, 12:04 PM   #48 (permalink)
silverkw's Avatar
Tell me about it! Grain filling is a PITA, but once it's done, the rest is a piece of cake.
Unread 04-10-2012, 12:26 PM   #49 (permalink)
KTM
KTM's Avatar
Looking good!
KTM is offline   Reply With Quote
Unread 04-10-2012, 12:47 PM   #50 (permalink)
likea45's Avatar
Fill. sand. repeat. Fill. sand. repeat. I know the drill. This is what separates us from those who would Krylon their Strats and call it good
Ignite the borealis
Unread 04-10-2012, 10:56 PM   #51 (permalink)
Pennstate913's Avatar
what grain filler did you use?
Pennstate913 is offline   Reply With Quote
Unread 04-11-2012, 12:12 AM   #52 (permalink)
very nice!
AxAxSxS is offline   Reply With Quote
Unread 04-11-2012, 12:33 AM   #53 (permalink)
silverkw's Avatar
Timbermate from Stewmac. Followed the instruction on their website as well. Relatively painless, but still quite painful comparing to any other part of the whole finishing process.
Unread 04-11-2012, 12:40 AM   #54 (permalink)
crompo's Avatar
That really is looking good.
Nice work !
I like the way you set up the bridge / stoptail.
By the way - where did you get the stoptail from with the adjusting screws ?
Wayne
crompo is offline   Reply With Quote
Unread 04-11-2012, 12:49 AM   #55 (permalink)
likea45's Avatar
You think? More than building up nitro?
Ignite the borealis
Unread 04-11-2012, 01:02 AM   #56 (permalink)
silverkw's Avatar
Well yeah, for nitro coats I just shoot a coat then go play some guitar for 30 minutes then come back, can build up pretty quickly on a Saturday when I don't have to go shopping with the wife.
Wayne
That's basically just a regular Gibson wrap tail. Mine is TonePros with locking studs. You can get regular ones from Gibson, Pigtails, Faber (with locking studs), etc.
Unread 04-11-2012, 01:23 AM   #57 (permalink)
likea45's Avatar
I meant more the act of building up then wet sanding then building up. I tend to go to the extreme with it so it could be perhaps why that's my most grueling part.
Ignite the borealis
Unread 04-11-2012, 09:48 AM   #58 (permalink)
52trapeze's Avatar
Looks slick!
Danelectro Guitars
Fender Guitars
Gibson Guitars
Fender Amps
Vox Amps
User of JM Rolph Pickups
User of Jonesy Wiring
52trapeze is offline   Reply With Quote
Unread 04-11-2012, 02:07 PM   #59 (permalink)
Knarbens's Avatar
I spent 10 Euro for this used drill press: Yours looks better though
Congrats on your project so far. I'll be glad once I drilled the stud holes at the right position, also.
09-2008 Orville Les Paul Standard
06-2012 finished first guitar build
12-2012 my 2nd guitar build(s) ...
Knarbens is offline   Reply With Quote
Unread 04-15-2012, 07:14 PM   #60 (permalink)
silverkw's Avatar
A few more.
Made a small mistake when spraying the back, but it's corrected. I have the base coat on the front as well.
