Old 09-02-2008, 10:38 AM   #1 (permalink)
Send a message via AIM to bigdaddy496 Send a message via Yahoo to bigdaddy496
floyd rose kit
i have seen some floyd rose kits that require no routing out of the body, wondering now where can i get one? it looks like you simply take the stop peice out and put the floyd rose on, anyone have more info? where can i get one?
To tyrants, I am the day of reckoning; to the oppressed, the hope for the future.
bigdaddy496 is offline   Reply With Quote
Old 09-02-2008, 08:05 PM   #2 (permalink)
alexvdl's Avatar
Re: floyd rose kit
Try searching ebay. They pop up once in a while, but keep in mind they will cost you around 200 bucks or more.
The system is just an original floyd rose, but the sustain block is removed and the tremolo is attached to a groundplate which you can attach to your exsisting les paul with 2 studs going into your tailpiece bushings. You will have to remove the ABR studs or unscrew your nashville studs. The groundplate will cover the remaining holes. You could use your exsisting tailpiece studs like I did, but there should be special studs included with this system.
I have used this system on my lp classic, but my neck angle wasn't big enough, so I couldn't get the bridge far down enough.
The two studs for the floyd rose are screwed into a square hardened piece of steel that are pushed into the cast groundplate. Because of the spring tension of the 10 springs at the back, the tremolo applies foreward pressure to these studs. The hard steel inserts will disform the soft groundplate, so the studs will tilt a bit foreward. I have experienced this on 3 units so far. This will make it hard to keep your guitar in tune.
You'd also need a kahler locking nut behind the nut or you can use locking tuners and a graphite nut. IMO it's not worth installing a locking nut, as you will have to drill two holes in the headstock (I did it... I regret it).
Oh by the way, you can only use the tremolo as dive only. You cannot pull up notes. The upside is that you can tune your guitar in drop D or other lower tunings.
Here's a pic of the system fitted to my LP classic:
alexvdl is offline   Reply With Quote
Kahler vs. Floyd Rose FLICKOFLASH The Custom Shop 17 06-02-2009 10:12 PM
Anyone see a Les Paul with a Floyd Rose? El Toro Gibson Les Pauls 83 12-20-2008 10:16 AM
FLoyd Rose Question? JBLesPaul107 My Other Guitars 18 07-18-2008 12:02 PM
My Bigsby mod, just as good or better than a floyd rose. Paul The Custom Shop 4 06-08-2008 05:20 AM
LP Standard with Floyd Rose acaciadesign Gibson Les Pauls 27 04-30-2008 07:26 AM
