Old 08-25-2008, 12:19 PM   #1 (permalink)
Aerosol Laquer Questions
I plan on spraying a homemade LP with reranch aerosol lacquer. I will have to do it outside since I don't have a proper spray booth. My question is what conditions do I need to have? Is it temperature, humidity, relative humidity within a certain range?
Thanks for any input
jwc574 is offline   Reply With Quote
Old 08-25-2008, 01:17 PM   #2 (permalink)
Dino's Avatar
Re: Aerosol Laquer Questions
Ugh ... I don't recommned spraypaint at all, but if you must ...
I'd be concerned with humidity, wind, (and bugs).
Just pick a nice pretty day with low humidity (and no wind) and you'll be fine.
I strongly suggest you to take it inside to dry though.
Dino is online now   Reply With Quote
Old 08-25-2008, 04:50 PM   #3 (permalink)
I was going to spray inside a portable wardrobe as many here have suggested. I suppose I could do it in my basement but I am a bit worried about the fumes etc. I have a proper mask and can open windows but I thought I'd take it outside to be safe.
Old 08-26-2008, 07:32 AM   #4 (permalink)
japasul's Avatar
If you use a decent filtered mask, youre good. But make sure you got good ventilation anyways...
japasul is offline   Reply With Quote
Old 08-26-2008, 08:31 AM   #5 (permalink)
Dino's Avatar
Another spraycan tip : Set your cans in hot water just prior to spraying. It helps with atomization and provides better flow.
Old 08-26-2008, 10:40 AM   #6 (permalink)
Thanks Dino.
Old 08-26-2008, 12:38 PM   #7 (permalink)
The smell is bad, ventilation is a must. Contrary to many, you can get good results with spray cans. Definitely warm them up first. Get the tap water hot, fill up a bowl and put your cans in, just like if you were chillin beers.
This burst was done with Stewmac Vintage amber and Red Mahogany.
bigdakota is offline   Reply With Quote
Old 08-26-2008, 12:53 PM   #8 (permalink)
Dino's Avatar
Nice!
I've painted alot of guitars with spraycans.
Painting with cans usually isn't a problem ... clearcoat it.
Old 08-26-2008, 01:23 PM   #9 (permalink)
Texas07R8's Avatar
Originally Posted by Dino View Post
Nice!
damn straight......
Texas07R8 is offline   Reply With Quote
Old 08-26-2008, 01:38 PM   #10 (permalink)
Very nice. Thanks for the tip
Old 08-27-2008, 10:54 PM   #11 (permalink)
Don't forget to get a can of anti-blush spray. In the high humidity areas, your paint will haze up.
Rick
rick13 is offline   Reply With Quote
P90 questions.... st.bede Pickups 71 07-23-2008 12:54 PM
laquer finish GuitarGod319 Gibson Les Pauls 2 07-07-2008 06:13 PM
how to questions..... st.bede Luthier's Corner 2 04-29-2008 11:41 PM
Laquer Question Slackerprince The Custom Shop 13 03-12-2008 08:12 AM
Pot and cap questions Liam Historics & Reissues 49 12-20-2007 05:05 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
