Old 08-22-2008, 06:48 PM   #1 (permalink)
xsouldriverx's Avatar
switch questions
is the standard LP 3-way toggle switch the same as an on/on/on (dpdt) switch?
im asking b/c im using a mini switch for a kill switch and im thinking of putting in an on/on/on switch instead of the usual toggle so it would match a bit better.
2007 Gibson Les Paul Classic - Wine Red - Tom Anderson H1- (neck) H3+ (bridge)
2005 Ibanez H.R. Giger Iceman
VHT PittBull 50-CL (with 6 band EQ)
xsouldriverx is offline   Reply With Quote
Old 08-23-2008, 05:15 PM   #2 (permalink)
japasul's Avatar
Re: switch questions
It really depends on the switch. If it is one hot lug and two circuit lugs then yes, its the same. But if its one hot lug and THREE circuit lugs, then no, it's not the same and it wont work.
Cheers!
André
japasul is offline   Reply With Quote
Old 08-23-2008, 05:16 PM   #3 (permalink)
japasul's Avatar
My suggestion is take your multimeter and set it to coninuity, then test the switch at each position to see what contacts it estabilishes.
Old 08-23-2008, 08:33 PM   #4 (permalink)
hmmm good to know, thanks for the info
I aged my switch tip Sony Oengui Epiphone Les Pauls 22 07-01-2008 06:03 PM
No kill switch on epi lp red_devil Epiphone Les Pauls 11 06-23-2008 09:31 PM
PRS 5-way switch in LP... carydad The Custom Shop 4 05-29-2008 08:24 AM
Switch Knob ALS682008 Historics & Reissues 3 05-09-2008 08:29 PM
changing a box switch to a LP switch... loaded six string The Custom Shop 3 01-31-2008 06:25 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
