Old 08-19-2008, 10:14 PM   #1 (permalink)
2 p-90s, one volume, one tone? help please!
Trying to wire my LP build with this wiring scheme... (I'm using single conductor P-90's with the braided wire)
It appears the pickups go through the toggle first and then to the pots. My question is where is the ground on my toggle switch?
Is it the lug on the back? I know the two front lugs are for the pickup leads. If its the lug on the back then where does the hot wire exit the switch to the pots?
Any help wold be greatly appreciated! Excuse my ignorance.
jwc574 is offline   Reply With Quote
Old 08-19-2008, 11:18 PM   #2 (permalink)
captain tightpants's Avatar
Re: 2 p-90s, one volume, one tone? help please!
Attachment 2987
Attachment 2988
Attachment 2989
Bingo, that's the ground. Wire your braided ground from the pickups to this. OR you can wire the pickup ground the the volume pot, and run a ground wire to that back lug.
Wire the hot from each pickup to the outer leaves, wire the 2 inner leads together, that is your hot signal to the volume control.
Old 08-20-2008, 09:52 AM   #3 (permalink)
aha.. the leaves separate. I didn't notice that. Can't thank you enough.
Thanks Capt
Old 08-20-2008, 05:15 PM   #4 (permalink)
You might want to swap out that import switch---they have a disturbing propensity for shorting out. Try a Switchcraft...only a few bucks more and it lasts forever.
ES350 is offline   Reply With Quote
Old 08-20-2008, 09:24 PM   #5 (permalink)
Thanks Capt
No problem hope it works for ya!!!
Volume and tone pot tapers Papa_lazerous Tonefreaks 2 05-08-2008 11:55 PM
Help wiring one volume and one tone toneguy86 Tonefreaks 5 03-31-2008 04:10 PM
LP DC standard-anybody add tone and volume pots? I want 2 tone and 2 volume knobs. Blues4U The Custom Shop 1 03-16-2008 05:46 PM
1 Tone 1 Volume Ejecto Tonefreaks 4 03-01-2008 07:21 AM
Volume and tone pots juca Gibson Les Pauls 6 12-14-2007 02:15 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
