Old 08-01-2008, 09:26 AM   #1 (permalink)
Smile Potentiometers and Spin a Splits?
Hello all,
I just finished installing Seymour Duncans Hot Rod set into one of my Les Pauls. I wired it up for " Spin a Split" and it sounds great.
I have a minor problem though. The volume knobs don't respond til I get to about 7 on the dial, so all of my volume is in the last bit of rotation on my volume. I used (4) CTS Long Shaft 500K Audio Taper Pots and wired it per Seymours diagram.
I have wired a number of guitars, modified and even built an amp before and haven't ever had a problem?
Thanks,
John
jcr_consulting is offline   Reply With Quote
Old 08-05-2008, 07:13 AM   #2 (permalink)
Re: Potentiometers and Spin a Splits?
In case anyone else has this problem in the future. I tried some different resistors across the hot tabs on the pots to modify the taper. I started with 220k and worked my way down til I got what I was after. Ended up choosing a 1k ohm. Smooth gradual volume increase from 1-10. I used 1/4 watt resistors they are plenty for this type application, they take up very little room and they are .99 cents for a 6 pack at Radio Shack.
New Spin on Weather Checking..? JoeShell1110 The Custom Shop 15 07-01-2008 12:23 PM
Gibson Custom Shop Potentiometers KajArcprows The Custom Shop 1 06-27-2008 05:58 AM
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Our Network: Marshall Amp Forum | Guitar Pickups Forum | Music Gear Forum
