Old 07-13-2008, 02:59 PM   #1 (permalink)
Turning Down Large Post Metric Bridge Posts?
Hmmmm, hate this Epi bridge, want to add Nashville of ABR without dowling and redrilling the bridge post inserts, so...
...anyone ever turn down a large post metric thumb post to the ABR hole diameter (.175" diameter)?
Thanks...
djd100 is offline   Reply With Quote
Old 07-13-2008, 03:41 PM   #2 (permalink)
lp_junkie's Avatar
Re: Turning Down Large Post Metric Bridge Posts?
would the stud spacing work, I have thought of doing this as well.
I want to go to ABR1 instead of Nashville though, so I may have to plug and drill.
LP_Junkie now on MySpace
Les Pauls and Marshalls- Hammer of the Gods.
EPI/MIJ Modders (Orville-Tokai-Burny-Greco-etc.)
lp_junkie is online now   Reply With Quote
Old 07-15-2008, 11:50 AM   #3 (permalink)
dwagar's Avatar
someone sells conversion posts, Nashville to ABR1. Stewmac maybe?
Don
my favorite toys (one wants to be a '59, the other is a '59):
dwagar is online now   Reply With Quote
Old 07-15-2008, 02:53 PM   #4 (permalink)
Large post spacing (2.913) appears close enough for either Nashville (2.930", as the Nashville bridge has a tapered hole with lots of wiggle room) or Gotoh Standard Post ABR (2.913"), or ABR-1 (2.900").
The problem will be losing the plating on the top of the post during machining, so perhaps the Gotoh Standard Post ABR or ABR-1 will actually work better as the bridge holes aren't tapered, so the post doesn't have to be as high etc. It'll cost around $80 to strip it and re-plate so it's not worth it IMO.
I'm going to turn some down today and slap on a 60's ABR as a test, so we'll see...
Old 07-16-2008, 01:42 AM   #5 (permalink)
Hmmm, I just noticed that these specs from StewMac aren't accurate in all cases. I measured some Nashville studs/posts, and some ABR's and there's some variation, so I've decided to order the small-post Gotoh TOM from StewMac, and measure it when it gets here prior to turning down the large post post-thumbwheel, just to be safe.
So, that means it'll be next week before I do it...
Old 07-16-2008, 06:33 PM   #6 (permalink)
goofballone's Avatar
Why not buy a tone pros set for you Epi??
Some say moneys bad for the sole
bad for the rock, bad for the roll
bad for the heart, bad for the brain
bad for damn near everything...
goofballone is online now   Reply With Quote
Old 07-18-2008, 10:14 PM   #7 (permalink)
Gotoh's are the same as TonePros minus the set-screw.
I'm looking to change the look from the large post to the smaller Nashville or ABR sized post, without changing inserts and messing with the finish.
Old 07-23-2008, 10:04 PM   #8 (permalink)
Turned down the Large Post Metric Thumbwheel's post to .160" today, and added an ABR post sized Gotoh Bridge (great improvement over Epi Bridge).
Easy, and the plating on the end even stayed put!
Conversion Bridge Posts? djd100 Epiphone Les Pauls 11 07-13-2008 01:49 AM
Bridge posts on a Gibson Classic ... what size (imperial) ??? classic Gibson Les Pauls 3 07-02-2008 01:38 AM
turning an ABR-1 bridge into strap locks. Paul The Custom Shop 1 01-29-2008 05:57 AM
When I post, the threads do not show up in 'new posts' DeafDumbBlind Kid The Backstage 1 11-08-2007 09:15 PM
ABR1 bridge posts - brass/steel sapi Tonefreaks 4 07-14-2007 12:42 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
