#31 (permalink) | |
Re: Sanded the back of the neck of my Classic
Do you mean like Fender Mist & Wipe Finish Enhancer or any type of mist in a bottle? I have plenty of those so I'll give it a try. Thanks.
sidewinderdayton.com It's not a hobby, it's a way of life. |
#35 (permalink) | |
Kind Regards, Ryan "Time is a great teacher, but unfortunately it kills all its pupils ..." "Every book is a children's book if the kid can read!" - Mitch Hedberg MLP Thread Pirates Cabin Boy ![]()
#36 (permalink) |
i posted a thread in the Luthier's Corner but i figured id tag it on to this thread as well because it might get seen more... anyways when I sanded my neck I left a thin strip of lacquer on the edges of the neck for the binding and a little past it and was wondering if anyone knew if there would be any adverse affects to going ahead and sanding the lacquer off the entire neck, binding included so its all uniform and smooth/absent of the lacquer? If anyone knows please do tell because If its ok Id like to get started on it after I get off of work in a few hours. Any help is very much appreciated!
#37 (permalink) | |
"Now Known as The Post-O-Matic 5000" MLP Thread Pirate ![]() Ye' First Matey'
#38 (permalink) |
even sanding over the entire neck, back and fowarth... wet sanding works best as well... also dont spot sand ... 0000 steel wool is great if you just want to satan the finnish a bit
#40 (permalink) | |
![]() Join Date: Jul 2007
IMO when lacquer has hardened, with a good polish, it's going to be smoother than a sanded neck.
------------ Don my favorite toys (one wants to be a '59, the other is a '59):
#41 (permalink) |
right, you can buff it with the steel wool and it will take a very small bit of lacquer off with out going all the way though, making the feel of the neck smoother
#42 (permalink) |
i beg to differ... my 03 classics neck, even when cleaned/polished/buffed still didnt compare to how fast it is now. ... this is because of the nitro finish IMO.... However, my Epi is Polly and when the neck is cleaned/polished/buffed i dont see a need to sand it.
#43 (permalink) |
I really think the trick is finding the right polish with lacquer. My 01 R9's neck feels like glass.
#44 (permalink) |
what do you use?
#45 (permalink) |
heres mine Roman did it since it was over for a setup.
![]() LOVE IT.Feels way nicer and smoother.Looks great too i may do it to the whole guitar!According to Roman he said he used 400 grit to remove the gloss and steel wool to make it nice and smooth.
#46 (permalink) |
im getting a new neck with no finish and i want to sand it down to shape it a bit more like the assymetrical 08' standard neck. what grit sandpaper should i start with since im not going through any type of finish and i want to change the shape of the neck. should i do the wet sanding too and end up with the 1000-1200 grit sand paper
2007 Gibson Les Paul Classic - Wine Red - Tom Anderson H1- (neck) H3+ (bridge) 2005 Ibanez H.R. Giger Iceman VHT PittBull 50-CL (with 6 band EQ)
#47 (permalink) | |
#48 (permalink) |
will do, thx alligatorbling. im starting with a pretty fat neck so i do have a little bit of leway if i goo too much with the 200 grit.
#49 (permalink) |
i recommend taking some detailed pics of the neck before you start so you can stop once in a while and get a visual idea of how much you've taken off. also remember to wipe down the neck and run your hand over it/play it every so often to see how it feels because once its gone you cant put it back lol
| Les Paul Classic neck profile, old and new? | lastinline | Gibson Les Pauls | 7 | 07-02-2008 08:29 PM |
| I just sanded the back of my neck down. | yossarian_lives | Epiphone Les Pauls | 27 | 06-25-2008 11:04 AM |
| got my classic back from greg!! | stryker59 | Luthier's Corner | 1 | 05-22-2008 09:27 PM |
| One Piece Les Paul Classic Body Back? | Thomas Ochoa | Gibson Les Pauls | 14 | 05-09-2008 09:23 AM |
| Making the back of my neck less "sticky"... | tiedstick | Epiphone Les Pauls | 42 | 11-06-2007 12:43 AM |
Our Network: Marshall Amp Forum | Guitar Pickups Forum | Music Gear Forum
