#212 (permalink) |
Epi Verification Expert
![]() Join Date: Jan 2008
Re: Jonesyblues Custom Shop & ToneMojo.com
Hmmmm clever.
Epiphone Elitist SG Faded Cherry (Tone Mojo'd and WB'd) Faded Cherry Epiphone SG G-400 Flamed Cherry SunBurst Epiphone Les Paul Plus Top Fender Mexi Oly White Strat Squier Natural Vintage M Jazz bass Peavey Classic 50 SG's FTW |
#213 (permalink) |
Hey, if it works and sounds great, I don't care what you do to it.
#214 (permalink) |
Capacitor Ambassador
![]() Join Date: Mar 2008
You can play it like that for a while with the 50's set up, and then if you want you can change cap from center lug of vol to pickup lug on vol. and that will give you more modern wiring. You will also have the volume bleed kits that are included to tinker with as well
#215 (permalink) |
I'll just leave it as 50's style wiring. I have that in my other Sg and it's just great. Also how do you instal the Vol bleed kits, and can you explain what they do? I forgot... Whoops.
#216 (permalink) |
Yeah I include a little drawing, pretty simple mod they just solder across the two hot lugs on vol pots. Normally when you turn your volume down your highs start to drop out. The bleed kits keep tone crisp at any volume level.
#217 (permalink) |
Perfecto. I was wondering, since my soldering iron sucks, can you just throw them on for me? Is it an addition charge?
#218 (permalink) |
No extra charge, I can install the bleed kits when I build your rig if you don't like the soldering iron
I try to encourage people to do some of there own mods though...
#219 (permalink) |
Well if I had a 40 watt iron it would be another story. Check out this modding I did before though.
#220 (permalink) |
Looks like 50's wiring with some heavy duty solid core electrical wire, and those HYREL Caps look familiar, I only use 30 watt Weller pencil style soldering iron for all my work and it gets the job done fine. To much heat on the Pots can mess them up....
#221 (permalink) |
are the relic'd 15s sprague or hyrels??
Saltaire's Vicars "Post Tenebras Lux" ---------------------------- |
#222 (permalink) |
The .015's are Spragues marked Vitamin Q, the .022's are Sprague HYREL 5% mil sec PIO Q type ![]() |
#223 (permalink) | |
That copper wire was horrible work with though. Although it has virtually no resistance, compared to the wire in their before. I got those caps from Martinsixstrings. He was having a sale so I snagged 4 for 10 bucks
#224 (permalink) |
Yeah that must be 12 or 14 g house wire...good for 220v,,,he,he better than that tiny wire for sure. I use the 22g solid core vintage cloth wire on most of my harnesses, it is pretty easy to work with. Pics are of some of the Relic'd 22g
#225 (permalink) |
Must be easy to work with if it bends
That stuff I used was so bad. I wired it to the input jack for the LP, pushed the jack into place and prayed the solder didn't crack. Thank god it didn't.
#227 (permalink) |
jonesy, how much of a spread was there on the batch of K40Y-9s you received?
gibiphone just north of the mexican line "God Bless the self-righteous, ever' last one of 'em" --Slim Pickens |
#228 (permalink) |
Well I noticed out of the 10, K40's I got some were marked 10% and some were marked 20% tolerance so it varied a bit between those kinds, but not much overall from cap to cap. The 20 of the K42's in green case were all very close and were all spec'd 10%
#229 (permalink) | ||
#230 (permalink) |
Hi I am interested in making this modification to my epi les paul, I play a mix of hard bluesy rock, punk, and high gain metal
what would you recommend for a nice bluesy classic tone that can still crunch when hit with a whole lot of overdrive? also..my friend is curious on a classic jimmy page wiring harness, what kind of caps would you use for those? i am an amateur when it comes to the soldering, but I am more than willing, is it just as simple as a lug on the volume and a lug on the tone? sorry for rambling lol THANKS!
1998 Epiphone Les Paul Standard MIK BABY! Peavey Vypyr 75 Rocktron Classic Wah '78 Boss OD-1 |
#231 (permalink) | |
#232 (permalink) | |
#233 (permalink) |
#234 (permalink) | |
Any of my .022 PIO caps would open up your tone, for rock, blues or metal even country or jazz for that matter. Good caps are warmer and more expressive for all kinds of music. These caps help out a lot especially if you still have original epi pu's. The Jimmy Page rigs have been getting the Spague .022 HYREL PIO for this past year. Bleed kits are optional... Note: Your pickups need to have 4 wires for the Jimmy Page Wiring to work. epi's stock pu's usually just have the 2 wires, so you nee to upgrade to some Shep's handwounds or a pair of Gibson or Dimarzio pu's with 4 wires. ![]()
Soundclips mp3's Jonesy's Sound Clips ![]() Tonemojo Videos on Utube Tonemojo.com & jonesyblues custom shop You can contact me at jonesyblues@yahoo.com GOD ROCKS!
#235 (permalink) | |
Yeah, I looked close and some had the 10% and some were marked 20%??, thanks for your input...Right now I have a pair of the K42's in my 99' Gibson Les Paul Special and am really digging the way it sounds... |
#236 (permalink) | |
safe to assume the 22's will work with either application?... thanks again
#237 (permalink) |
yeah .022's have been Gibson spec for 50 years they work good all around, some guys here at MLPF have been running an .015 on the neck for a little more room on the dials, and .022 on bridge. The Russian .022's in green case are actually reading around .018, they would be great on neck.
I have a pair of those Green K42's in my 99' LP, Stock Gibson pu's 490R 498T??...neck pu reads about 8.3K and bridge pu is hot like 13.95K, for testing the wiring was converted back to 50's wiring. I am running vol. bleed kit on neck but not on bridge(installed after testing), both tone pots are 500K CTS, Rocking wide open crisp Tone when dimed, warmer and thicker as I roll off tone, but still plenty of upper mids & highs. Rolled way back theK42's get a great woman tone, I look for the "wha" spot somewhere towards the end of the curve but not all the way. IMO the .022 K42's (.018) have a more noticeable mid/upper mid curve, tight lows...
#238 (permalink) |
you are the man jonesy..thanks for the sweet information...sorry to mess up your classified thread!!!
i will do some digging around in these 2 guitars and hopefully bug ya for some caps thanks again!
#240 (permalink) |
Still have some of the Russian K42Y-2 green case .022's left..they are reading around .018, great sounding caps. I have some "Holiday specials" going on with those an my "Relic" caps as well.PM me if you are interested in anything? Thanks & Peace, Jonesy
| FS:Gibson Custom Shop Quilt Top Les Paul Custom Color 1994 | porterburst | Member Classifieds | 9 | 06-04-2008 06:23 PM |
| FS - Gibson Custom Shop Les Paul Custom - Brand New! | Marko1986 | Member Classifieds | 0 | 05-16-2008 03:40 AM |
| Dumb Question : Custom / Custom Shop | nakleh | Gibson Les Pauls | 5 | 05-02-2008 01:58 PM |
| gibson les paul custom made in the custom shop? | dorrus | Gibson Les Pauls | 6 | 12-31-2007 10:26 PM |
